MAN Wheel Fitting
  • Please log in to reply
5 replies to this topic
#1 Poptopshed
Poptopshed
    Member
  • Korpral
  • 28 posts
  • LocationThe Middle of the Uk
Posted 17 September 2017 - 09:38 AM
Hello,
I am getting ready to fit my MAN Kat 1 wheels with 1400r20 tyres. Do i need to remove the nuts that hold the brake drums on before fitting the wheels, Will the new tyres catch the body if fitted with the drum nuts?
Do steering locks need adjusting too?
Any other things i need to watch out for?
Please post some pictures of your trucks with them fitted, i am still waiting for my last 2 rims from Germany.
Thanks
Jon.
  • kristaga likes this
#2 rocknroll
rocknroll
    Member
  • Korpral
  • 26 posts
  • Locationkonstanz
Posted 10 November 2017 - 08:03 PM
Edit: mistake by reading the post.I ment the outside nuts not the inside on the brake drums.
Regards
#3 Wingflyer
Wingflyer
    Member
  • Administrators
  • 2,487 posts
  • LocationEslöv
Posted 10 November 2017 - 08:43 PM
No! Do not drill the rims! just remove the inner nuts, that's all.
You may want to find new outer nuts with integrated tapered washers, the original nuts tend to cut into the rim when tightened sufficiently.
I have used my TGB40 with these wheels for a couple of years now and no problem what so ever. You can’t’ however use chains, they will interfere with the steering arms…
  • kristaga and Poptopshed like this
TGB11 x2, TGB1314, Ambulanshytt 1315, TGB30 med stabshytt, TGB40 med 6 ton kran, TGB40 snart med krokväxlare, Startbil TL12, AmLastbil 806, 939 Viking med kran, Bv202, TP21 Sugga, Snöslunga m/64 (Scania DS11 slungmotor på Volvo 939 chassi), Boeing Stearman :)
#4 Wingflyer
Wingflyer
    Member
  • Administrators
  • 2,487 posts
  • LocationEslöv
Posted 10 November 2017 - 08:55 PM
http://www.terrangbi...g/?hl= man kat
  • rocknroll and Poptopshed like this
#5 rocknroll
rocknroll
    Member
  • Korpral
  • 26 posts
  • Locationkonstanz
Posted 11 November 2017 - 06:05 PM
Edit: I mean the nuts from outside...not on the drums.. my mistake.
I did it but with professional equipment -to like the original rims. But dont do it self when you dont have the equipment to do it professionel.
You can't use the chains beacause the offset are more close to the middle of the truck. It touch def the arms. When my pressure was low for the bush often my tire touch the arms with the flank
I dont know how it is with 14.00r20 tires- i used 16.00R20 . Thats verry big!( to big)
The original rims have a smaler offset
Regards
  • Wingflyer and Poptopshed like this
#6 Poptopshed
Poptopshed
    Member
  • Korpral
  • 28 posts
Posted 17 November 2017 - 08:47 PM
Thank you, I got hold of my final two rims this week soon be getting them fitted. What tyre pressure do you use on a 40 car with 1400r20 fitted?
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
