CV Boot
Zeeri
Hi!
Sorry to start this topic which I am sure has been thoroughly discussed here. I am having a hard time with the search though as my English to Swedish search keywords are probably not ideal.
I am planning to do the CV boots on my new to me tgb1315. I have the seals. I have a great understanding of what needs to be done. I did run across an old thread on another forum that pointed to a thread here that I can't find. It showed how to remove the brake/gear assembly from the portal box but leave the brake lines attached. Then I could replace the CV boot without having to bleed the brakes.
If someone could point me to that thread or any others that might be helpful I would surely appreciate it.
Thanks for your help!!
Here is my new to me TGB that has already been camperized
post-8847-0-54096800-1441209126_thumb.jpg.
  • Like 5
Hi and welcome to Terrängbil.net!
A whole bunch is written about boot replacement. Try to search for "damask" or "damaskbyte".
Below two examples:
http://www.terrangbil.net/forum/index.php?/topic/2323-damaskbyte-p%C3%A5-11an/?hl=damask
http://www.terrangbil.net/forum/index.php?/topic/11479-ta-bort-hjulv%C3%A4xel-f%C3%B6r-att-byta-drivaxeldamask/
It has been established that the quickest and least messy method is to pinch the brake lines with suitable clamps, disconnect the brake lines, then remove the whole hub/gear unit.
Good luck!
WF /Admin
Hi!
attachicon.gif20150817_113224.jpg.
And we are curious about the inside..  -_-
  • 4 weeks later...
  • 3 weeks later...
Hi Zeeri.
Could this one be your tgb halfway through the camper conversion by the precious owner?
I don't think that one is mine. Mine was a radio car. And Bob the previous owner raised the roof of the cabinet because he very tall.
