orcomeno Postad 31 Juli , 2015 Rapport Share Postad 31 Juli , 2015 Hello everyone, I am an owner of a 1980 Volvo C202 and I am in the process of fixing some parts to get it back running. I live in Texas and was looking for help on where to find some parts: The front and rear wheel break cylinder, the car dashboard (speedometer, odometer, fuel, temperature gauge), and the remote brake fluid reservoir . Thanks! 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Peter Strandberg Postad 31 Juli , 2015 Rapport Share Postad 31 Juli , 2015 C202 share alot of land rover brake parts Info from http://www.terrangbil.net/forum/index.php?/topic/10273-hjulcylinder-c202-landrover/ Cylinder left front 2 needed BritPart GI 52569 LandroverGirling 600200 Land Rover Series 109 LWB 6 cylindersCylinder right front 2 needed BritPart GI 54966 LandroverGirling 600201 Land Rover Series 109 LWB 6 cylindersCylinder left rear Land Rover 243297 LR Series II 109 SW w/ 2.6L petrol eng.-1971Cylinder right rear LandRover 243296 LR Series II 109 SW w/ 2.6L Petrol eng.-1971 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
orcomeno Postad 31 Juli , 2015 Författare Rapport Share Postad 31 Juli , 2015 Thank you so much for your help! Ill check it out Citera Länk till kommentar Dela på andra webbplatser More sharing options...
orcomeno Postad 14 Augusti , 2015 Författare Rapport Share Postad 14 Augusti , 2015 Hello everyone, Does anybody know where I can find the steering box seal for the Volvo C202 1980? Thanks! Citera Länk till kommentar Dela på andra webbplatser More sharing options...
volvomix Postad 16 December , 2015 Rapport Share Postad 16 December , 2015 Hi im also looking forparts the front singnal lights a full winch from a to z also the wind shield wiper motors and blaids Citera Länk till kommentar Dela på andra webbplatser More sharing options...
white lighting Postad 8 Maj , 2016 Rapport Share Postad 8 Maj , 2016 Hi all if anyone now were I can get a clotch and disk for c202 79 or the up to date parts # in tne tranni and transfer box I would be very thank full for the info thanks again p.s im in need of the alumimum cover and rubber seal on the rear lights,and the front signal lights thanks Citera Länk till kommentar Dela på andra webbplatser More sharing options...
white lighting Postad 8 Maj , 2016 Rapport Share Postad 8 Maj , 2016 Hi im looking for info an swaps in the clutch disk disk and clutch for m45 tranni thanks for any help. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
tajman365 Postad 8 Maj , 2016 Rapport Share Postad 8 Maj , 2016 The parts list for download for your C202 can be found at the top of the page when you open the heading C202 topics. there is a good breakdown of the gearbox in it. It should be a M45 with FD51 transfer box. Well that's what I put in my 1978 C202. I found that the clutch driven plate/disc was the same as used in a Bedford C F Van. 10 spline ,1 inch center hole. The clutch pressure plate is the same as from a landrover series 2 or 3 I think. Borg and Beck 50052/ 52509 Both I managed to get on Ebay and are fitted and working. Sorry I can not be more specific. 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Kjell Niklasson Postad 8 Maj , 2016 Rapport Share Postad 8 Maj , 2016 The clutch is the same as in Volvo 164 with b30e engine. Also, release bearing from 164 fits. The clutch is 240mm or 9,5inch in diameter. 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
white lighting Postad 10 Maj , 2016 Rapport Share Postad 10 Maj , 2016 Much thanks to tajmam and kjell niklasson for your in put but do u noe were I can get them I have been taking a part some other parts of the tranni and transferbox and am looking for this partssynchonizing cone. 4 of them I have the parts manual that I down loaded from this site but dont have an idea as to where I can get them con any one help me with this the most moptant parts are1 the input shaft 1220310_5 ,4 synchronizing cone they are all the same # 1232616_1or 1220327 .companion flange 1220325_3 qt of 8. Need bearing 1381565_9 I would be very thank full for your help with this if u should ever should need so.e this from boliviaor come down just call. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
eile Postad 10 Maj , 2016 Rapport Share Postad 10 Maj , 2016 Gear case part will fit from volvo 240,740 with m45, m46, m47 , on mine I have m47 gearcase but with a mix of gears from m45 c202 because I don't like nedelbearings. take a foto of what part you need. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
